Lt Dan
Greetings Fellow RV-4 Enthusiasts & Experts!
I'm currently in the early stages of purchasing an RV-4 I found in Louisiana. This would be my first airplane so I could use a bit of advice. I placed a deposit on the aircraft and I'm about to go look at it. Since it's a small community I figured I would ask a few questions you might be able to help me with.
1) The airplane is N69WL built by the guys Lewis and Winningstad. I thought I might ask if anybody knows anything about the builders?
2) It's now based in Broussard, Louisiana and after I go look at it I would like an independent and unbiased A&P to conduct a conditional inspection. I figured I would start asking around based on the RV White Pages unless somebody here can already point me in the right direction.
3) I have read the Newbie info on this website but if anyone has any additional advice on what to look for when I go down there, it would be much appreciated. The other thread I found with a similar question really did not cover any specifics. I do know that I should inspect the spar near the front seat pan (but what I'm looking for...???); look for obvious signs of abuse on the weldments/buckling in the firewall; look for rudder cracks; look at the Airworthiness, Registration, POH, and Operating Limitations; inspect the wiring as much as possible (it was built in 1990); and general condition and signs of build quality like rivets being over driven, straightedge to this and that. Anything else you would want to look at on a personal pre-buy inspection? I'd like to see if I can fly it to take it up and see if it flies straight and true, but other than that I don't really know what I'm looking for.
Any help is much appreciated!!
Dan
Few more items to consider
By no means an expert but having owned an RV-4 project for a short time, a big deal for me personally, was a phlogiston spar which can be identified by the gold anodized spar and also be sure that the fuel tanks were not built with slosh compound which is a white color and covers the whole interior of the tank.
If it's a 1990 model I doubt it has a Phlogiston spar. My -4 has the old style wing spar and it's built like a tank. Things like engine mount weldments and slosh in tanks are easy fixes and in my opinion wouldn't be a deal breaker.
Don't remember exactly when the Phlogiston spars came out, but I built my wings in 1990 and did use their spars. OTOH, the spars in the kit came predrilled and were not difficult to build properly. I wouldn't be afraid of home built spars.
The early kit RV-4 spars came drilled undersized as I recall. The builder then finished drilled or reamed to correct size. The difficulty some experienced, especially if they tried to finish drill with a hand held drill, was drilling a straight hole through several spar web thicknesses. The drill would tend to walk resulting in an oversized hole. Vans fix was a thin steel reinforcement spice plate. Proper drilling and installation of the splice plate brought the spar back to full strength. Perhaps this is what the individual was talking about when it was mentioned to look at the center spar section? RotaVR.
RV-4 Things to look for
Well, Lt Dannnnnn, “My mama always said, ‘Life was like a box of chocolates. You never know what you’re gonna get.’
Sorry, couldn't resist!
I just went through the first time buying process myself. I'd never owned any airplane before and had only a few flights in RV-7s and -8s. I was looking for either a RV-4 or RV-8 with a strong preference for a -4. With the help of my -8 owning brother-in-law and Vic Syracuse, I found a great airplane and am very happy.
I'll list some of the things that were important to me but the most important thing, by far, is to get a good pre-buy inspection from somebody that knows what they are doing. There are several folks on here that can do that for you. I highly recommend you use Vic Syracuse if he's available. He's close enough to you to make the trip and will provide you with superb value for your money. If there are issues, he'll give you the leverage necessary to negotiate as his word is like the word of the almighty in the RV world. You can reach Vic here, by private message or phone at - (404) 307-5133, or (770) 898-2222. You can also check out his website at www.baselegaviation.com. Best of all, Vic stand's by his pre-buy customers through the entire purchase and initial flying process. I had a ton of questions after I acquired my airplane and Vic was always a phone call away.
Now, to that RV-4. Things to consider / inspect:
- engine weldments (as you've already mentioned)
- cracks in gear legs / engine mount
- fuel tanks condition - NO SLOSH, NO LEAKS
- avionics (a big deal for me - get a glass panel or plan on upgrading - ADSB 2020 compatibility)
- rear seat controls - beyond a stick, do you really care?
- paint condition, exterior and interior
- quality of installation and condition of all wiring
- fuel leaks - look closely
- tail wheel spring / mount type / condition
- presence of trim tabs, especially aileron (rudder tab expected, ailerons not so much)
- aileron and elevator bushings - no vertical play
- elevator cross tube play - hold both sides and try and move in opposite directions - little to no movement allowed
- compliance with all service bulletins
- consistent flying history - an engine that has sat is potentially worse than a higher time engine.
- read every page of every log book. Is the history well documented?
- read the airworthiness certification - did the builder certify the airplane for the regimes of flight you intend?
- ANY damage history. IF you accept any, make sure the repairs are fully documented - you'll have to explain it to the next buyer.
- Prop strikes are especially common - while A&P's differ, most want a fully overhaul of the engine, especially if a metal prop was involved.
- age and condition of tires, wheel's and brakes
- metal or plastic brake lines
- types and condition of lights - check to make sure they work
- canopy opening / closing mechanism - a "taxi stop" is essential for controlling cockpit temperature on the ground.
- battery and alternator age and condition, type of regulator
- type and location of throttle / prop / mixture controls - formation flight?
- engine hardware condition - all control linkages, hoses, exhaust attachments
- cowl attachment condition / ease of removal
- search the FAA and NTSB database by N number for history
Just a few of the things that came to mind.
Call Vic!
Good luck,
Randy
Well, Lt Dannnnnn, ?My mama always said, ?Life was like a box of chocolates. You never know what you?re gonna get.?
Call Vic!
Good luck,
Randy
Um....what he said. :eek:
Thank you all so much! You guys are amazing. This is exactly what I was looking for. I'm about to go down there and check it out and I will be looking for all these things.
If I get to fly it, I'll try to check out some things like:
takeoff/landing performance
climb/cruise performance
engine parameters in all phases
trim and ability to fly straight on its own
avionics and radio operation
Mode C check from approach
Is there anything else one should look at in a test flight?
oil consumption
See if the present owner has been tracking it. anything more than 1qt every 5 hours and you could be looking at an expensive repair soon.
Did you buy it? If so, lets see some pictures!
I had to turn it down for three primary reasons.
1. Condition was not as represented. There were many, many cracks all over the place that I have no interest in fixing at this point in my life. The fuel tanks also showed signs of leaking.
2. The seller had been signing off his own annuals for 7 years and is not an A&P.
3. The seller knew about an AD on the prop for blades liberating in flight and chose not to comply.
Even though I didn't buy it, I have many pictures anyway. Let me know if interested.
More 2 cents
I have a -4 that I built (O-320/160HP FP), and have been around many, as well as the F1 Rockets. I see you are fairly committed to O-360/180HP, and lots of power. A well built RV-4 with an O-320/160HP and C/S wont be far from it, and it will widen your search base. If your flying solo most of the time, you really wont need the extra HP anyway. Once you fly an F1 or Harmon Rocket with 250-300 HP, you will want that instead until you have to write the check. I however like the handling of my light RV-4 over the powerhouses. Also, to clarify a couple spar observations, The factory kit spar, which has to be built-up by the builder is also offered as "prebuilt"(for a fee) by Phlogiston industries. In other words, VANS sends kit pieces to them, and they do the build-up and finish work. They are easily identified as being gold anodized, and very nice !..but they aren't physically different than what a builder would assemble from the kit.
Too Bad
Sorry to hear it didn't work out. I know the feeling. You put a lot of work into those visits! Keep looking - you'll find a good one soon.
Good luck!
Thanks for the great info. Like you said, Bill, the right RV-4 with an O-320 is definitely not out of the question due to their wonderful efficiency and low operating cost. Though I will say, I've certainly seen less constant speeds on O-320s than on O-360s, that's for sure.
