lrfrey
Is there any reason to not power up the SL30 Nav/Comm without the Nav Antenna installed? I couldn't find anything in the manual about it. I would like to check the Comm radio but the Nav antenna is in my wing tip, which is still in my barn 10 miles away. (Don't have that much co-ax).
Larry
It's OK
No problem since the NAV portion does not transmit....
However, if you are near a VOR, why not add a length of cheap co-ax to the NAV connector and just strip about 24 inches of the shield off at the end? You might be able to check out your CDI this way...
gil A
PS the no antenna problem is an overload of the Comm transmit power devices... not applicable to Nav..
