P phi75 Member Mar 12, 2021 #1 Hello where you put the temperature sender unit? Vent left side not good there is warm air from the engine
Jpm757 Well Known Member Mar 12, 2021 #2 I have 2 of them, each one is mounted on the inboard inspection panel on each wing. No issues. Last edited: Mar 12, 2021
DanH Legacy Member Mentor Mar 12, 2021 #3 I usually say underside of the wing, anywhere outside the prop blast, but I'm not militant about the latter
riseric Well Known Member Patron Mar 12, 2021 #4 Same here Jpm757 said: I have 2 of them, each one is mounted on the inboard inspection panel on each wing. No issues. Click to expand... If you're talking about AOT probes, I did almost the same, not on the inspection panel but just aft. Attachments IMG_5581.jpg 278.6 KB · Views: 147
