C cwharris Active Member Aug 12, 2014 #1 Has anyone ever used J.B. Weld for attaching the Trailing Edge Wedge instead of using Pro Seal? Which one works better for this application?
M Mike H Well Known Member Aug 12, 2014 #2 Are these the elevator wedges? If so I would use sealant, it will be lighter since it spreads more evenly and you will use less. The sealant will also flex and will not have a tendancy to disbond if/when the skins flex.
