az_gila
After 18 hrs I have the start of the "dreaded blue stains" from the right tank upper baffle. ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have Vans repair kit and now have 5 large holes in the rear baffle. I have started scraping away the somewhat marginal proseal fillet along the rear baffle, fiddly work but quite doable.
My real question is "what tool do I use to add a new fillet?" Since it's essentially in a blind location and mirrors are needed my usual popsicle tool or SEM air powered dispenser won't work.
How have others got their goop into place?
I intend to remove as much of the existing skin/baffle proseal and hen use adhesion promoter under the new proseal. Since it will be 85 F plus in the afternoon in the hangar the proseal should flow fairly well.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Some things I found out already that might help others -
1. 5 inch holes are easily cut with a m Milwaukee hole saw from the local Ace store. The manager said it's probably the only one he's sold of that size.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
2. The part of my Pepto-Bismol cowling that was cut away for the oil door makes a great proseal scraper.
