I dunno why this particular part is giving me such a problem. I?ve screwed one up already because I kept fiddling with it. This is the T-705 tank attach bracket that needs to be fabricated. I?ve included several pictures here. A couple of things give me worry:
-I fabricated the bracket to fit in the leading edge rib just fine, but by my count there are 4 rivets that I won?t be able to buck due to the bracket being in the way. Do I cut notches where those rivets are for a blind rivet (seems to me those would be some pretty big notches), or can the bracket be situated up a little higher to make room (as in pic 3)?
-I guess I just don?t understand the plans for the other side of the bracket. What is ?R1? mean? Is that a 1? radius? The + on the bracket, how far up from the bottom of the flange is that (I guess if R1 means 1? radius, it would be 1? down from the top). I guess there isn?t enough measurement here to make me happy. Whats with the bottom of that bracket? Why is there an inside radius?
I really feel stupid now as I just noticed the ?half scale? in big lettering. I guess I should have plotted some marks on my bracket after measuring the plans. After all the cutting and polishing, my brackets came out like so (see pic 4). My bracket is an 1/8? under 3 3/4?, do you think this will suffice?
I?m sending this same post to VANS in the morning, but I?m really into the whole immediate gratification (or immediate disgust if it turns out screwed up another one), so I posted here first.
