CDBridgesRV7A
Active Member
Good Day Folks,
I'm a little confused with my fuel tanks at the moment. All of the ribs (except the outboard one) are sealed and riveted in place. I'm going to use flop tubes for inverted fuel pick up. What do I do with the hole for the fuel pick up tube located in the tank access plate? I'm using the larger, centered, hole for my float sender. Do I seal the other one or do I install 2 fuel pick up tubes in each tank (1 normal and 1 flop)?
Thanks for the help.
Chris
Chris
