TallManInOhio
Member
Hello All, First time here, lots of good info! I have admired Vans since I first took a ride in an Rv-6 In 1994! However, Times change, and I have grow! (Both height and girth!) I am considering an Rv-8 purchase, and need input from anyone that has built one! I had the chance to sit in one this past weekend( Hopefully get a flight next week!) and It was a little tight. The rudder pedals were set all the way foward. I would like to know if anyone has setup one to fly solo from the backseat, and what the "Tall pilot" option is all about? The Rv-8 I'm considering is partially built, will this be an issue to modify? I should mention that I'm 6'8" and 260lbs. Thanks, Mike
