Flip it around, repeat until worn out, replace ... is what it is
......some hills aren't worth dying on......![]()
Mine is the same. I just flipped the wheel Saturday.
One thing I did notice is that I had basically zero pre-load on the tailwheel bearing, so it spun very freely. On landing, the thing would always spin around like a bad shopping cart wheel until I got the tail solidly planted.
This time I put some drag on the bearing, similar to what I put on the mains, and now it tracks straight on landing, much better!
Drag on the bearing…did you just tighten the bolt through the bearing tighter? My Tailwheel shopping carts on landing too…if this is a solution it would be quick and easy!
