Instructions says to "make 3/4 square from scrap aluminum to shim any gap between the WD-409 Tail Spring Mount and the F-811 Bulkhead Assembly"
In the middle, between both of them, the mount does not contact the bulkhead.
Wouldn't it be better if the shim was triangular shaped corresponding to the whole face of the mount?
This to better distribute the load from the mount to the bulkhead and to eliminate the off-set angle (top to bottom) between the bulkhead and the mount created by the shims?
Thanks !!
![PICT4943.jpg](/community/proxy.php?image=http%3A%2F%2Fi154.photobucket.com%2Falbums%2Fs244%2Friseric%2FFuselage%2FPICT4943.jpg&hash=438189760b79c3c168efb4af06a6c409)
![PICT4945.jpg](/community/proxy.php?image=http%3A%2F%2Fi154.photobucket.com%2Falbums%2Fs244%2Friseric%2FFuselage%2FPICT4945.jpg&hash=9ee9888b11f92f8c68d6a429543ee9da)
Thanks !!
