Per the Flyleds instruction sheet:
The Tail Strobe needs one or two runs of standard 18 to 22AWG wire for power. You may link the Strobe and Position inputs together for use with a single power circuit.
Connect the light to the appropriate Strobe and Position switches on your panel.
So you only need standard and not shielded wire.
