Nitty
Has anybody been able to take System32 EFII engine data from the cockpit controller and display it on an HXr EFIS? GRT says they can read CAN bus data but Robert at System32 says the telemetry interface uses the VT100 data format.
If not, then the only option is to incorporate the GRT EIS. Can I use the same EGT/CHT/etc input that is going to the cockpit controller and T it to the GRT EIS?
Dale
