Tbone
Is there a "methodology" on switch placement or layout that will promote ease of use during the flight phases. I have searched the web but nothing specific. I am at the point of switch layout and will soon drill for those locations. I will be using Bob Nuckolls mag/start layout "no key", vision a/p, electric flaps, e-bus alt feed, position lights, strobes, dual landing/taxi lights with wig/wag, avionics master, boost pump, pitot heat, DC PWR master. I have outfitted the panel with Dual Dynon D180/100, HS34, Vizion 385 a/p, 8000B audio panel, garmin 430w, SL40, GTX327, heated pitot, ACK 409 remote, 12v acc. Plug and USB charging port. I'm trying to have a "ease of flow" for proper switch placement. Any suggestions or advice. I have this equipment in hand so not interested in any "what if you swap or change this out" type of comments....But won't object to any simple cost effective changes. RV 7 TU, panel cut, IFR .
