Rather than running the 2020 wiring to the AV-50000 I am considering splicing the new GPS into the exiting 4 wire bundle. Has anyone done this, and if so was there any degradation of signal strength or other complications?
I'm trying to avoid opening the instrument access panel as it will ruin the paint and the seal will be a bear to remove, and then re-seal. And access through the SV hole is small with the d-sub location difficult to reach as well. Just looking for a short-cut that will have no negative affect, if possible.
