Old Mooney cooling drag discovery
I have had similar experiences in another 'store bought' brand.
My 1966 Mooney C model was built with a very large cooling lnlet all the way around the prop. Huge. Additionally the oil cooler is mounted in the lower fwd cowl right out front, with ram air passing directly into the vanes.
One day, I noticed an oil streak along the outside of the lower cowl. It was coming from the lower edge of the cowl cutout for the oil cooler, down on the chin of the cowl. This position is really as far fwd as you can get, so I assumed I had a leaky cooler. I opened it up, and cooler and hoses were dry, but the inside bottom of the cowl was moist.
I couldn't see a leak anywhere. Washed the engine, flew it and finally found the leak. It was coming from a small fitting in the accessory case, running down the rear of the access case, and when it hit the firewall, the airflow pushed it forward all the way up front (under the airflow coming down from the cylinders) and uphill on the inner surface of the 'chin' of the cowl then out the cooler opening. Total distance travelled fwd? Approx 30" that slopes upward around 3", and the final climb is another near vertical 3" climb!
I was shocked that the air was making a 180 degree turn and going uphill! That made me realize why the cowl flaps were ineffective in the air. A significant amount of the air was exiting the oil cooler opening up front!
This configuration yielded oil temps consistently high-always 200-240. And CHT was very low.
I believe the cooling opening was waaaaay too large for the job at hand (O-360) in a 140 Kts TAS airplane. How do I know? I bought an STC'd kit that reduced the inlet by approx 70%. I picked up approx 7 kts TAS. Oil temps were now the opposite: very low 160-180 (I now have the oil cooler half covered to elevate oil temp), and the CHT's did the opposite as well, in climb, 400 degrees, then in cruise 350-375.
And for all of us
Sam James Plenum Chamber fans out there, this Mooney was manufactured with an all alum
plenum chamber back in 1966, and it
still had rampant cooling drag due to Mooney's overly large inlet configuration. So, just having a plenum is not a panacea, everything must be in balance to achieve cooling drag nirvana.
AS to the Kitplanes article, every FWF configuration has it's own particular quirks. I would avoid any broad sweeping statements about all baffling for all planes.
And RTV? Totally necessary now, with my cowl inlets closed down. Case in point: I changed the engine, and put the Mooney stock plenum back on, and ran her up. CHT's were thru the roof. RTV'd the interface between the top of the accessory case and the plenum's 'back wall', and the temps came back down. Dramatically.
The only sweeping statement I'll make on baffling/cooling drag is this:
Chris Zavatson 's website (
www.n91cz) has the most scientific instrumentation of cooling drag I have seen anywhere, he measures pressure in the cowl in various places as well as airspeed of incoming cooling air, and he teaches you how to do it in your plane! And.......he's good guy.....(for a Lancair guy),. If you are a student of cooling drag reduction, I'd go there and read his excellent paper on the subject. Could save you hundreds of hours of trial and error.
Chris Z-we'v not met, but I'm an old friend of Trey's who turned me onto your site and your award winning ship. Impressive
Art in Asheville
