Went out Sunday to get some glide data relative to prop settings. Did'nt believe it the first time so did it again. Didn't believe it that time so did it again today. Here's the data, all at 80 KIAS, throttle closed:
Prop full RPM (fine pitch) - oil Press 62- MAP 8"-1090RPM - 1050 FPM Descent
Prop Full Coarse - oil Press 56 - MAP 8"- 700-1100RPM - 1050 FPM Descent
No Change!!! I found that you could vary prop RPM with speed and took it down to 60 KIAS and 400 RPM. Pretty uncomfortable shaking (think continuous shut down shudder). At 400 RPm and 80 KIAS, still no change in descent rate.
Tried WOT. Yep,less pumping work resulted in faster RPM to 1300, and increased descent to 1300FPM.
Not calling BS on anyone else's experience. I was also a believer in coarse prop, more glide. I suspect it is highly engine/prop related so for me with a 200 RV and IO-360, it just didn't happen. Wanted it to happen, tried three times, just didn't happen. Can't argue the data - No increased glide for my set-up. YMMV.
