ccsmith51
I am considering an RV that has a VM1000 and a BMA EFIS G4. I know that both companies are no longer with us.
Is there someone else that provides technical support and parts for these units, or when they die are they done forever and I will need to replace them?
Thanks.
A good avionics person/shop can often repair boards with bad resistors, diodes, etc.
I've repaired a number of LCD TVs just by looking for an obvious problem and replacing parts on the boards within (usually capacitors).
Thanks.
No technical or repair support for the BMA efis. They are usually replaced with working used units or a device from a current vendor.
