I figure if anyone should know, it would be you guys. There is a Superior oil sump that comes on a Superior O-360 and it has a cone in it above the carb which increases air flow (and resulting HP) to the runners vs the Lycoming one which is just flat. What is the part number for the sump, I want to order one but can’t find any other info on it other than a comparison image.
Has anyone installed one and noticed a solid improvement in power?
Thanks!
Thanks!
