dougknight
A friend at our airport blew the bottom out of his sump on a new superior IO-360(10hrs, rv6a) when it backfired the other day on start up. It was the light-weight bakelite sump and left a hole about the size of a grapefruit in it.
He has located and recieved a cast aluminium one as a replacement.
Our question is, on re-installing the new sump and new gasket, do you fit them together dry or do you need some sort of gasket sealer applied to the surfaces first. Such as silver paint on a head gasket for an automobile engine or a splash of oil on the "O" ring of a oil filter to seal things up. Any little tricks out there to make sure this thing doesn't leak in the future?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
We have asked local A&P's / IA's and get about 50% suggesting "do it dry" while the other 50% suggest some sort of sealant. What would you do?
thanks
doug
9a
90625
thanks
doug
9a
90625
