jcarne
Patron
Soooo... having a borescope is a gift and a curse at the same time.
Would this yellowish-greenish area on the valve be sulfur deposits? It shows up on #3 and 4 but not 1 or 2. Also only shows up inside exhaust passage and not on the face of the valve.
Anyone know if this is an issue? I'm guessing not but I don't know what I don't know. Thanks!
If it is, nothing u could do about it right? Lean always till it hurts… change oil regularly. Fly often. Quit the playing with the scope…:)
#1 - you can not depend on the color rendering of the scope to be accurate. If you want to get a scare look at your throat.
#2 - It is just lead deposits.
#3 - don't get too excited about what you see in the scope until you have some more experience. Keep posting . . .
#4 - the resolution IS really good, is it the new VA-400?
If you want it to look like new....... Just run Propane....:D
plus, it's only 4.2 lbs per gallon. But the weight of the tank makes up for it...:(
Thanks for the replies guys, I'm just trying to learn as much as I can when using the borescope and it seems the only way to really do that is ask people with more experience than myself. Just seemed odd that it appears on the back two cylinders and not the front.
Normally wouldn't scope this cylinder but I'm checking each oil change now to see if my exhaust valve is rotating on #4 or not.
The scope is a VA-400 I purchased about a year ago. Never did look to see if it is their new version or not.
Bingo, that's why I keep posting my pics, just trying to learn
Very little chance it is sulfur. Sulfur is quite volatile at low temperatures so unless your CHTs are in the 200 degree range any sulfur would go out the stack. Since its an exhaust valve, highly unlikely it would be at temperatures low enough to condense sulfur. My semi-informed position as a geochemist that dealt with sulfur for many years.
CHT
Check the CHT on each cylinder at cruse, they should be +/-10 degrees of each other. I balance the CHT by trimming or adding aluminum tape to the inlet baffling at cylinders 1 and 2 (lycoming). Your back cylinders may be hotter than the front two; add tape to the front baffling. The factory RV baffling is very well designed and should only require a 1/8" to 1/4" adjustment across the cylinder to make a 20 to 50 degree difference. It takes a couple of iterations to reach an even temperature across all cylinders. You should notice the valve look the same once you achieve equal CHT, provided all cylinders are the same age.
This will make you feel better...
(not mine)
It appears to be a loaded up valve (carbon and lead combustion byproducts). As others have mentioned, brutally lean the engine on the ground - to the point that it stumbles in ground idle, and then just add a touch of mixture to keep it running. Ground idle is the main culprit in fouling plugs and valves due to the lower temperatures and cylinder combustion pressures.
A couple hours of running at full power should help clear it up, but as long as compressions are good, I wouldn't worry about it. Consider running LOP.
Ya just to be clear though the first picture is my valve, not the second one in the thread.
I do run LOP or at peak pretty much exclusively and lean aggressively on the ground. The deposit layer on the valve is insanely thin as my valve is really quite clean with no thick buildup anywhere. I just thought the color was interesting as I haven't seen that yellowish greenish color before.
