UnPossible
Hey - with the wings on and incidence drilled, I want to get the wing tips drilled and the ailerons and flaps all rigged correctly. Unfortunately, I'm having some trouble with the left flap.
1) Both ailerons are set to neutral as measured by the tooling holes in the wings
2) The control stick is vertical, and the aileron bell crank jig lines up for both wings
On the right side, you can see that I can adjust the flaps via the linkage so that when fully up, they are pretty much perfectly inline with the aileron.
However, on the left side, the when fully up is ~0.15" below the aileron.
Looking under the plane, it appears that the flap is hitting the fuselage in the fully up position
Are there any tricks or suggestions as to how I can get this flap up an additional 0.15"?
Jason
![4l5ymf.jpg](/community/proxy.php?image=http%3A%2F%2Fi41.tinypic.com%2F4l5ymf.jpg&hash=a56cf213165bdccae75dbefaaf7c5e4d)
![2j1ocp2.jpg](/community/proxy.php?image=http%3A%2F%2Fi41.tinypic.com%2F2j1ocp2.jpg&hash=979b33baa389b7aacfd9eda6687d60cb)
![140agpi.jpg](/community/proxy.php?image=http%3A%2F%2Fi44.tinypic.com%2F140agpi.jpg&hash=8fd50f7b04f438eb240b18df3e320d33)
Jason
