calpilot
OK, I'm stumped! I have dual Garmin G3X Touch (7") PFD / MFD displays. How do I get the soft key "Lean Assist" to show up on my engine monitor page? I can't seem to find it in the documentation.
Disregard.... Found the answer on a GArmin forum, not obvious.
Gary (Experimental and Light sport DAR - Pacific Northwest)
I just found it the other day... its in the configuration menu. i'm going off memory here, so i may be wrong, but i think you have to go into the Engine menu, and then click on either the fuel flow sensor or maybe EGT and you'll see Lean Assist enable or disable.
