Is it ok to run strobe power wiring, autopilot servo control wiring, landing light wiring and remote magnatometer wire together?
Thanks for the advise.I ran my tail strobe and tail light wires together down the RH side of the tail cone and the wires for my elevator trim servo and magnetometer, which is mounted on the rear deck, down the LH side of the tail cone. I was careful with grounding and it's the first aircraft that I've flown not hear strobe noise in the headset.
DC power wires and strobe wires are OK to run together but try to keep them away from antenna, audio and data cables.
Jim Sharkey
RV-6 Phase 1
I would not run all of those wires together. You can run the strobe and landing light wires together. You can also run the A/P and magnatometer wires together. The more you can separate those two bundles from one another the better. If they have to cross one another at some point, it is best to have them cross at right angles to each other. Now, all that is what is "best." Compromises to the "rules" are normal. Just minimize them as best you can.
GREAT advise, thanks lots. What would be the minimum distance apart? If I ran one on the top of a rib and the bottom fo the other is that sufficient?
R./
C.![]()
