I downloaded the latest image (ver 1.2 ) which provides a serial output.
Q1: Is the serial output through the GPIO pins or does it require a USB/Serial converter ?
Q2: I have a Keyspan USA-19HS USB/Serial converter that did work with an image provided by a VAF member, it does not work with the latest image.
Do I need a converter with the CP2102 chipset., I dont think the Keyspan has that chipset.
I read that certain software commands may be required to make things work, I thought such commands would be part of the image.
Additional thoughts about USB devices, does it matter which USB ports a device is connected to, what happens if you move the devices around. Is a device logged into the EEPROM and will only work on a specific port until the EEPROM is reset ?
Peter
Peter
