Fearless
I am having an issue where when I try to start my plane and while idling and not moving, I get an overspeed condition on my flaps. I have talked to Chad about this and he thinks I have an issue with my GRT Sport on the airspeed readings side of the house. I have gone into the VPX Configurator and set my flap ranges to 0 as well as set the Overspeed setting to 300 MPH which I will never hit. Because the flaps are wired into the VPX box I haven't tried to set the flaps to disabled. I can clear the fault through the Configurator but it keeps coming back on occasion. The only way to clear the fault is through the Configurator and I can only do that on the ground with the computer I have the software installed on. I have not seen anything in the GRT Sport setup to make me think its being caused/triggered there. I bought the VPX Sport to use the overspeed functionality as well as monitor my electrical system but this problem is causing me to regret that decision. I would like to have this solved before the first flight on the plane and not have to worry about a no flap landing. I do not have the Ray Allen flap position indicator on my plane.
