rv9aviator
I have never had a plane with more than one EGT probe. Now I have all four and I have no idea if this is normal or if I have a probe or EMS problem. When Idling and taxiing the EGT's are higher on the front 2 cylinders by 150 deg. When in cruise the EGT's are higher on the rear 2 cylinders by 150 degrees. The engine is an 0320-E3D fixed pitch RV9A. The readings run from 1300 to 1450 in both situations. The CHT's are pretty even across the board in cruise and on the ground. The engine is running perfectly. This is a simple mag and carb engine. Any thoughts?
