Draker Well Known Member Jul 23, 2019 #1 Looking for a name/source of this thick rubbery strain relief item: It's like heat shrink but much thicker, and provides not only strain relief but a nice transition when protecting wire with braided tubing.
R rapid_ascent Well Known Member Jul 24, 2019 #2 Ryan, Some heat shrink has a higher shrink ratio than others. That can result in it being thicker when you use a larger diameter and then shrink it more. I can?t say for sure if that is what you are seeing but I suspect it is the case. Ray
A akabud Active Member Jul 24, 2019 #4 There are LOTS of varieties of shrink tubing. Even extra thick. https://www.mcmaster.com/shrink-tubing
