Craig23
Hi All,
The Van's drawings call for AN365 stop nuts to attach the control surfaces to the HS, VS, and wings but I wondered whether most of you end up using drilled bolts with castle nuts and cotter pins. Do the DARs or FAA inspectors generally require the castle nuts?
