Veetail88
Id call Stein but it's the weekend. Course maybe you'll read this stein!
I bought all my avionics from Stein a couple of years ago and unfortunately I'm just wiring the components together now.
Anyway, the problem. Though I didn't have them do a complete harness, all the components came with very nice semi complete harness not all connected together.
Problem is, the wonderful drawing I received with it showing which wire connects to which pin on the different components doesn't identify wire color used.
For example, I'll have a shielded pair marked "GPS RS232 out A&B".
Inside the shield will be a white wire and a white wire with a blue stripe! It's quite difficult to track down the pin each is connected to as there is a very large bundle of wires to pick through.
Does anyone know if they use a convention, such as maybe the A wire is always white and the B wire always has the stripe or something like that?
I'd be cruising right along if I knew.
Thanks gang!
Thanks gang!
