I'm not sure where to post this, so I'll put it in my model type, but applies to all.
I'm concerned about using aluminum AN fittings (or any important aluminum components) in FF so people recommend steel. I've not seen stainless steel fittings, just steel. Is there not concern about galvanic corrosion between the stainless and the steel? Or does the benefit of steel on FF outweigh the risk of corrosion?
Thanks.
Thanks.
