billpilot1
Active Member
Has anyone done (or know of) a modification that has a stearable nose wheel on an RV?
Has anyone done (or know of) a modification that has a steerable nose wheel on an RV?
Yep and they dumped it on the production version.The yellow RV-12 has one.
MRT890
I think it's done this way in the C172 - cables pull springs attached to wheel. It makes the steering a little bit indirect, but it also dumps shimmy a little bit and save your feet from kickbacks when you ride on rough surface.You would probably need some springs in the system to keep the cables tensioned and allow the gearleg to move normally.
Before I finally decided to go TW I toyed around with the idea of a NW steering setup. I believe it could be implemented without too much pain as follows:
(snip)
When the rudder pedal is pushed, the opposite pedal comes back, pulling the cable. The cable shortens the distance between the pulley and stud, turning the wheel in that direction (snip).
Fewer brake fires?No need. In what way would a stearable nosewheel be better?
Fewer brake fires?
