The static port in the Van's kit uses two pop rivets which go thru the feuselage sides to get to external air. once "popped'" I would expect you would have a squashed 'Shop" head and the idea then is to connect your tubing on this.
Has anyone used this kit and does it work OK?
Thanks G
Thanks G
