benjam
Active Member
Evening all.
I am beginning to install the static ports and system in the rear of my build.
Although I can follow the stick diagram from Dynon, I can’t conceive of what the tubing will look like when installed.
Any piccies of what you did, please?
Static ports
Ben,
I can take some pics next time I’m at the airport. Send me a PM to remind me and I can forward pictures thru the forum or direct to your e-mail if you prefer.
Oly
this is what it looked like after I finished replacing the tubing and the ports a couple of months ago. Not Dynon specific though. Y manifold feeds a single line going to the panel for further distribution.
Location of, and the ports themselves, are important, plenty of threads on here treating the subject...
In your photo, isn't that a water trap on the left side of the aircraft, from the Y the line going over to the right side? Makes a loop that water will stay in.
I used the Dynon kit. The Y Connection location is higher than in the picture above. The Y Connection also lines up with the longeron for routing.
I put the "Y" at the top. My recollection is that the pressure distribution in a pipe is linear from the two ports if at different pressures, so if in a slip, the midpoint would theoretically be the average of the two. Also, it's a lot harder to get trapped water in the ports...
Here's what I dug out of my build log.
Static ports installed. I'm using the fancy milled ones instead of the factory blind-rivet setup:
First bit of tubing installed. The ADAHRS mount will be on the main longerons just forward of this bulkhead, so the T fitting is low on the port side and points forward:
Final setup with the ADAHRS mount in place:
Well, maybe not quite final. Before closing up the aft fuselage, I added a cable tie mount and attached the static line. This routes it a bit more positively and keeps it off the side skin. Overkill? Maybe, but that's a recurring theme with my build...
I don't have a great photo of that final bit of routing but maybe this will give the general idea:
