N804RV
Starting back to work again. Have a question?
I'm finally getting back in the shop after a long lay-off. I built the vertical stab before I had to stop last year.
Now, I'm working on the horizontal stab. the rear HS spar is done, and looks great. But, now I have a question:
How far back do I measure to cut the flanges back from centerline on the HS-702's? It looks like the call-out on view AA on DWG 3pp says the center of the bend radius is 4&7/16". So, this where I center the relief holes and cut back to, right?
Thanks in advance!
