wirejock
I installed cables to the starter today. First I removed the jumper per Vans. Big cable to the big bolt. Solenoid wire to the smaller one. I checked with an ohm meter and I read continuity between the smaller bolt and ground. Seems odd to have continuity there but I've never checked one.
Am I just reading the solenoid brushes?
Is the snubber diode installed?
....... I checked with an ohm meter and I read continuity between the smaller bolt and ground. Seems odd to have continuity there but I've never checked one.
No, you're reading the resistance of the coil of the starter-mounted solenoid. That's what pulls the pinion gear into the ring gear and also closes the big contacts of the solenoid to allow power to flow into the starter motor.
I think I understand.
Solenoid is a big electromagnetic right?
Yes. It is an electromagnet which does two things: it closes a pair of big contacts which complete the circuit to the starter motor and it pulls the pinion gear into the ring gear.
Thats why you don’t need 2 solenoids any more ! Ancient wiring was for lycomint
and early Ford type starters. Most aftermarket starters have solenoid such as yours . Tom
correct. You are reading the resistance of the solenoid winding for generating the magnetic field. It needs to be pretty powerfull and therefore needs a lot of current (5+ amps typical when also pulling the drive gear) and that means low resistance on the winding.
