I was wiring my starter yesterday and the WH-K910 wire wouldn't fit. I think that one of the ring terminals was incorrect. They are both the same size. It fits onto the relay at the firewall because that post is smaller. The post on the starter is 1/4" and it won't fit. I don't have a ring terminal that big, so I'll order some, but just wondering if anyone else has had the same problem.
Also wondering about routing the starter lines as manual says see op62, but that doesn't have anything in there about the starter. Section 43 of the manual shows a 360, so it's a little different.
I know these are pretty basic questions, I'm still getting up to speed on FWF. Riveting everything was the easy part!
Jeff
Jeff
