Andrew,
Yes, you still use the standard L/R Both setup for a Mag and Lightspeed. A small jumper comes with the key switch to disable the Lightspeed upon startup if you chose
to do so, however based upon the snippet from Klaus's website I've attached below, it doesn't sound like the jumper is needed ( I did remove mine and haven't had a problem ( some might say yet!!) ). The purported advantage to starting with the Plasma II+ is a hotter spark and quicker starts. In retrospect, I'd opt for one of the other solutions posted above and save the cost of the key switch for something else. If you use toggles or a push-button to start you'll never strap in and then remember the key
is in your pocket!
From
http://www.lightspeedengineering.com/Products/FAQs.htm#3
5.) What are the power requirements for the Plasma CD systems?
The current versions of Plasma CDI systems need a minimum of 6.2 volts to start operation. This is more than 2 volts less than the minimum voltage needed by the starter solenoid, thereby eliminating the possibility of kick-backs during starter operation.
Plasma systems shipped before December 20 of 2004, need 8.5 volts to start operation. This higher "on" voltage can cause a misfire if the starter current drain is high and/or the battery is weak and the voltage collapses below this threshold during cranking. Systems shipped before 2005, can be upgraded to have the lower voltage capability.
Once the engine is running, all systems operate down to less than 5 volts, should you lose your charging system.
Regards,
Rob
