I had my first power on last night, but got really scared. When I turned on the master, my prop started turning as well. I turned the master off quickly so the prop blade turned no more than 10 degrees or so, nothing is damaged and no one is hurt. But it sure scared me. After checking the wiring around starter relay, I found the diode is to blame. I installed the diode per instruction coming with it, but it is closed (showing about 600 ohm) from master relay to starter relay switch stud, while closed from starter relay to master relay. I am not electrically savvy, but is this just wrong? When it's wired this way, the starter relay is closed as soon as the master is on. Shouldn't the diode be wire the other way? I disconnected the starter relay diode, and all is well.
