Dayton Murdock
Hi All
My starter finally failed today I think it is the Bendix and I am having a hard time finding an old Delco starter for a O320 I like having The heavier starter to bring my CG farther forward is there anyone out there with an old starter they would like to part with
rebuild
I had my rebuilt at a shop that rebuilds starters and alternators and was reasonable and fast
Tim
6a
Just Lube It
The Bendix Drive is pretty easy to replace. A copy (pretty old, but still pretty good) of the Prestolite manual can be found here:
http://www.rushesroost.com/PrestoliteStarterAlternatorManual.pdf
Aircraft Spruce sells the Bendix Drives, one example is here:
http://www.aircraftspruce.com/catalog/eppages/starterdrives.php?clickkey=66484
Do you lubricate it regularly? I had trouble with mine and after taking the front end of the starter apart and freeing it up I got it working again. After that I squirted some LPS-1 on it every time I had the bottom cowl off and never had any more problems.
Thanks for the information:)
Dayton,
I was in your shoes several years ago, using a Prestolite starter for CG purposes. When it crapped out the last time, I found a flywheel weight ring (~10 lbs) and switched to the Skytec NL starter. I've been very happy with the conversion.
Just a thought.
Thank You for all the responses
I cleaned the bendix with solvent and installed it.
After recharging my battery (left the master on) and several ground starts I think it is good to go
