jsharkey
I have the standard Van's supplied starter solenoid with S and I connections. The I connection appears to be redundant per Van's wiring drawing OP-10. I also have the standard Van's mag/starter switch with an anti-surge diode supplied. From the switch instructions the diode should be installed between the start connection on the starter solenoid and ground. It shows two options, a single connection (same as master solenoid) and double connection solenoid, however the double connection one doesn't look like the Van's starter solenoid, but it does show the diode bridging the two connections and not going directly to ground.
Cutting to the chase - how do you connect the diode on the standard Van's supplied starter solenoid with S and I connections?
Jim Sharkey RV6 - Wiring
