steve murray
I went up this past weekend to establish best glide speeds for engine out condition. Climbed up to 12.5K and shut the engine down. I have a 3 blade MT electric constant speed prop. It took me a while to figure out how to stop the blades, feathering the prop and slowing down to a stall speed would not stop the prop. I needed to drop the nose and pull up to an agressive stall to stop the blades.
After the blade rotation was stopped, I transitioned from 90 mph glides and then 80 mph glides. At 75 mph I began to get stall buffeting? this is about 20 mph higher than my normal power on stall speed.
I climbed back to 12.5K and repeated the test with same results. The 75 mph stall speed really suprised me. The stalls were much more gentle than normal, and it appeared more of a porpoising up\down vs. clean stall break that I am used to with the engine running.
Any thoughts on the much higher stall speed of 75mph?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
