Reading a bunch of threads about fires, and firewall insulation etc, I came across one account of a fire (that ended without injury) where the fire actually apparently burned through the aluminum on the belly of the aircraft just aft of the firewall. I've seen such things mentioned on other threads too. When I think about it, I could imagine that a fuel leak around the mechanical fuel pump could spray fuel backwards towards the exhust pipes where the heat from the exhaust would ignite it. Seems to me this could end up creating basically a flame thrower directed towards the belly of the airplane.
We install a stainless steel firewall (some insulate this firewall), but even with the best firewall in the world, it seems to me a fire could still burn through the aluminum floor causing smoke and intense heat to enter the cabin that way.
Has anyone considered replacing the forward aluminum floor skin (under the area where your feet go) with a stainless steel skin? This would obviously have to be done at build-time. I guess this would imply a huge weight penalty.
