I've used the sub-d pins covered with heat shrink, soldered wires covered with shrink but the best permanent splices I've found are made by Raytheon I think...not cheap (about a buck each) but are spec. for aerospace use. They have a heat shrink tube, a ring of solder in them and heat activated adhesive. You slip the splice over the wire, twist the ends then use a heat gun..NOT A LIGHTER
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
....the tube shrinks, the solder flows into the wires then the adhesive fills the ends of the tubing. I believe I ordered them from Allied or McMaster. FWIW, I only spliced one wire permantly in the entire airframe, a ground wire that came up a foot short of the ground tabs. Everything else like flap motors, transducers etc. I put a sub-d or molex connector on.
