P
paul mosher
I planned on using the aluminum spinner from my blended airfoil hartzell prop but the backup plate is almost as large as the flywheel. I would rather not cut away the cowl to accommodate the spinner plate. This spinner is bolted directly to the flywheel, not retained by the prop bolts.
Any one know of a backup plate that will work?
