Hi all,
I've got an RV-14a with EXP IO390-119 with Hartzell HC-C2YR-1BFP prop. Currently have the Vans supplied S-601-1 spinner.
Does anyone know if the Hartzell polished spinner kit will replace the S-601 spinner, without cowl modifications? I understand that the spinner back plate and forward mounting will have to be swapped, but I really don't want to start modifying the cowl. Has anyone made this swap and can comment?
Thanks in advance!
Thanks in advance!
