tracy
Friend
Having to slot the forward spinner bulkhead again after a prop overhaul. Wondering how much material can be removed before the bulkhead would be considered too weak.
Tracy
There’s a couple of options. The prop shop that overhauled mine slotted the centre holes to allow for the new position.
another option is to remount the bulkhead in a different orientation that allows you to drill new screw holes and add more nut plate.
regards Peter
I know how to make more holes, its Already slotted about half the surface and I’m concerned about making more holes or elongating the slot.
