SuperCubDriver
I am about to install the spinner on a Hartzell CS prop. Once I read that there is a template for the blade cutouts. Where can I get this template? How did others make the cutouts?
Luckily I had an old hub laying around and could confirm it has the same measurements like the one on the delivered prop, so I can use this to simulate the spinner for the cowl fitting.
Spinner Template
The template is available from Hartzell as a .pdf file. Send me an email and I can provide a copy or you can contact Hartzell directly.
Good luck,
Mike
