a bit noob OT question here...
seems all the navigations are in kt,
why VAN's spec are in mph?
...Many people like to use mph because the numbers are bigger....
(sells more airplanes because they seem faster - same reason that $9.95 is better than $10 if you're selling somethign...)
Many people like to use mph because the numbers are bigger....![]()
Never been able to locate the knot line.![]()
Well, latitude actually. The length of longitude minutes varies with latitude.They are hiding as the minutes-of-longitude lines on your map.
--Paul
The vertical (longitude) minutes are constant.
