Bryan Wood
I ran into Earl Hibler Saturday at the local airport. For those of you unfamiliar Earl races a Glassair fixed gear taildragger at Reno. While talking about his plane we got into speed mods and some of the ways he was able to squeeze extra knots out of his airplane. It is powered by a 300hp IO-540 and has a propeller worked up for him by Sullivan Propeller at Hayward Airport, CA.. His prop was modified by twisting it to a "D" and then flying it and sawing off the ends and then repeating the same. By doing this he gained 18 knots. The goal that both Earl and Brian Sullivan had agreed on was to stop cutting on the prop when or if they could reach an "Indicated" airspeed of 270mph. They achieved that goal plus a little and stopped. I have no idea what altitude that was at and didn't think to ask.
What caught my eye though was tape that he had on his airplane. Every gap was taped with some kind of teflon type tape. This included the flaps and ailerons both top and bottom, the same on the elevator and rudder. The wing tips were taped to smooth the transition to the wings. He said the cowl is taped the same during races. The tape being used as gap seals intrigued me so we looked at my RV to see where it could be used to improve it. The ailerons and flaps are not able because of the hinge and the way the aileron leading edge drops below the wing when the aileron goes up. So we looked at the tail and he told me that using the tape on there would "Wake it up dramatically."
So the purpose of this post is to let folks know tricks that are being used to make planes go faster by the serious speedsters. I've seen Lancairs taped at Reno also and it blends in nicely. He mentioned the supplier which makes this product for sailplanes but this has also slipped my mind.
So where is this going? I'm wondering if anybody has tried taping on an RV and what the results are. And secondly, Mr. Bob Axom if you are reading this send me a private e-mail because I got Earl's card for you and he is receptive and anticipating a call and talking turkey with you about how to go fast.
Best,
Best,
