This is my list for slowing properly to land:
Plan ahead and slow appropriately.
instead of a 30 degree banking turn, move them up to as much as 60 degree banking turns.
In the down wind put the aircraft in uncorrdinated flight, meaning have the aircraft like in a cross wind landing, lots of right or left rudder and opposite airleron, you know a slip, but watch your airspeed, of course when you get it down, you take it out. Sometimes I'll use this 3 feet off the runway.
call your intensions and do a 360 tight turn on final.
Do an overhead with 360 turn, of course get approval or broadcast the intension.
Just pull back the power in downwind and keep it level, helps more if the idle can go way back, say 600rpm, when it's this low you need to add a little just before touchdown, the engine might quit or thump a bunch.
Of course you can use a slip to land to keep the airspeed proper once you get there.
